Before I start prying with a screw driver, is there a trick to removing the small panel that holds these two switches?
Also, how does one remove the cigerette lighter?
THX in advance
Arnold
Hazard and rear wiper panel
- Super Exceeded
- Vehicle: 1993 L300S
Re: Hazard and rear wiper panel
Ya, pry with a screwdriver.Super Exceeded wrote:Before I start prying with a screw driver, is there a trick to removing the small panel that holds these two switches?
THX in advance
Arnold
Cigarette lighter (just did this one in Artacoma's ride): take out the ashtray, reach around to the back and unscrew the ring that hold the lighter chassis in place. You can't spin the ring (because of the wire attached to it), so you have to spin the lighter chassis, and yes that's a bit of a trick. Or you could just rip it out like we did.
Is this where you're going to put the after-axle-drive-engage switch?
- Super Exceeded
mararmeisto wrote:Ya, pry with a screwdriver.Super Exceeded wrote:Before I start prying with a screw driver, is there a trick to removing the small panel that holds these two switches?
THX in advance
ArnoldRemove the switches first... I can't remember if the panel is held in with screws, but the switches are snap-fit.
THX, as for the switch, nope not there....
