Possible Brake Fluid leak
Posted: Mon Aug 02, 2010 4:00 pm
Just noticed that I had a leak in the front right wheel...checked the fluid which is oily, but has no smell, checked the brake area and realized the entire inside of the wheel is wet with this fluid. Checked underneath the brake caliper (???) and saw that the fluid was there and that this fluid is welling up on the inside of the tire...checked the brake fluid well and realized it was almost at about 5-10% full!!! Went home, checking to make sure the brakes were working, which they were, then parked it. Now, I just got back from a check-up at CCautos about 4 weeks ago, had the brake fluid tubes (???) replaced on all 4 brakes among some other things (part of a post I am working on). Is this something I could take care of myself or should bring the Vruck back up to ccautos? Any thoughts or ideas? I'll take some photos of this particular issue later today...
latest and greatest!
Thanks for the speedy response County Combs Autos! Will update later this week with PHOTOS! (I know some of you think under-carriage L400 photos are sexy!
