Page 1 of 5
Jensen's EGR Removal Blank Kits - Now With More Cowbell
Posted: Fri Jul 16, 2010 11:43 pm
by RichD
This started as me trying to help out in
this thread but it seems that there are different people looking to do different things and there was a bit of confusion so I've started a new thread of my own.
Yet Another Edit: Although I grew impatient and threw in the towel, Jensen picked up the ball and if you follow the thread, you'll find its not so dead.
- More-Cowbell.gif (17.46 KiB) Viewed 12893 times
Re: 1/4"(6mm) CNC-cut EGR Blanking Plate Kits
Posted: Sat Jul 17, 2010 1:36 am
by delicat
Good on you Rich to carry on Falco's project.
Not sure if you're aware but you don't need different design for the 300 or 400. The 300 style fits both perfectly. At least this is what MysteryMachine told me when I visited him. And from visual inspection I think he was right. That way you'd save money on the process... And $40 is a bit steep, it might be worth checking with other machinist... I've used one for my lift kit that was very decent and I'm sure Jesse could direct you as well.
Hope this help!
David
Posted: Sat Jul 17, 2010 3:56 am
by RichD
Hola muchacho!
delicat wrote:Good on you Rich to carry on Falco's project.
To be fair, he has his own project, which is a different approach.
delicat wrote:Not sure if you're aware but you don't need different design for the 300 or 400. The 300 style fits both perfectly. [...] You could also consider the option of doing the exhaust blocking plate which would need to be around a 1/4" thick.
The kit illustrated above includes an EGR valve blocking plate, an exhaust blocking plate. It is 1/4" (6mm) thick. It defeats the EGR (implying removal) in the 2.4 L300 and 2.8 L400, Pajero engines. It is thick enough to support a pyro probe mount.
delicat wrote:And $40 is a bit steep, it might be worth checking with other machinist... I've used one for my lift kit that was very decent and I'm sure Jesse could direct you as well.
I have submitted the drawings to CNC machinists around the lower mainland, as well as in the US. I'm looking for more machinists, and I've PM'd everyone who has mentioned that they can do or know someone who can do the job. I welcome any leads you have on machinists who might beat the quotes I've got right now.
Posted: Sat Jul 17, 2010 6:20 am
by lopar
Are the specs above for L400 blanking kit? I am thinking hacksaw + grinder + drill = me sore and tired, but save about $35.
What is being used for gasket, if anything? High temp RTV?
Posted: Sat Jul 17, 2010 8:57 am
lopar wrote:Are the specs above for L400 blanking kit? I am thinking hacksaw + grinder + drill = me sore and tired, but save about $35.
If you do it with a hacksaw/grinder and it's not easy on the eyes, just remember that it's right there in the open every time you open the hood.
I prefer the clean look. Good for Rich to make some.
My machinist is hit & miss. He's over 70 and works once in a while. Plus he's expensive.
Posted: Sat Jul 17, 2010 12:28 pm
by RichD
Just a heads up, probably going to pass the torch to Jensen on this as he responded to my PM and I think he's the man for the job. Watch this space.
Posted: Sat Jul 17, 2010 2:00 pm
by Luna-Sea
The kit is the SAME for the L300 2.5 4d56 engine and the L400 2.8 4M4O engine.
THE SAME! ok?
6mm IS close to 1/4 inch (0.2362204724409449 inches)
Around 40bux is what I paid too.
The only guys that can do it cheaper are these guys,
First thing I noticed was the sign on the shop....
- Weird kinda business.jpg (27.08 KiB) Viewed 12889 times
then met these guys..
- Whatz up guys.jpg (14.28 KiB) Viewed 12879 times
I asked about fabbing up some EGR plates and this
is what their response was...
http://www.youtube.com/watch?v=zCTBD4ZW ... re=related
Though they gave quite an energetic and enthusiastic response,they did not
really answer any of my questions.
I felt that perhaps other members of the club where better suited to
see this project through...
I WILL TAKE 2 SETS when the dust and and metal shavings settle guys.
Please and Thank you.
Right ON!
Posted: Sat Jul 17, 2010 3:37 pm
by lopar
Tripped across this one, may not be worth it after conversion/shipping and such.
http://cgi.ebay.co.uk/MITSUBISHI-DELICA ... 0608090117
Sent for quotes: 1 piece vs 20 piece order.
Will update when I get a response.
Posted: Sat Jul 17, 2010 3:39 pm
by delicat
Ok, my wrong if I didn't notice it already included both plates. In that case it's worth it 'cause cutting 1/4" steel with a grinder isn't fun. I've done it and don't think I'd do it again!
Count me for 1 kit for sure and possibly a 2nd kit if it fits the Safari (I'm pretty sure it will).
David
Posted: Sat Jul 17, 2010 3:46 pm
by lopar
These guys in Victoria have them in stock $15
http://enviroimports.com/
Any comments/dealings with them?
Posted: Sat Jul 17, 2010 5:14 pm
by lopar
jfarsang wrote:every time you open the hood
Great, got me all sensitive now..........
here's a clean looking kit....... send message for 20 piece quote......
http://cgi.ebay.co.uk/EGR-Removal-Blank ... 335f1aa96d
update when I get some numbers........
cheers
Posted: Sat Jul 17, 2010 8:30 pm
by Jensen
Hope to have something for you guys on Monday.
Posted: Sat Jul 17, 2010 11:27 pm
The important thing is that we get them made.
I would like to comment that if we are putting together 1/4" plates then they may as well be aluminium. The only reason they were made of 3mm mild steel is because you couldn't fit a 1/4" of aluminium between the EGR valve and the mount (bolts too short). This way we avoid the electrolytic reaction issues.
Posted: Sat Jul 17, 2010 11:42 pm
by delicat
Can't do them all in aluminum, the exhaust side gotta be steel. It gets real hot down there...
From reading the original post do I get it right this time to think both plates will be 1/4" thick? Couldn't you save more money by getting the intake side much thinner as it doesn't need to be that thick... 1 or 2mm should be plenty.
And as the wise Falco said "as long as they get done"...
Posted: Sun Jul 18, 2010 5:57 am
by lopar
K, this is the kit I mentioned above. Sourced through Google ---> Ebay ---> moderator over on Delica friends (
http://www.delicaownersclub.co.uk).
contents: Removal kit consists of:
X2 6mm Laser profiled high grade steel blanking plates
X1 Rubber vacuum blanking pipe
X2 High tensile M8 bolts
X2 BZP M8 flanged locking nuts
X2 M8 spring washers
X2 M8 flat washers
Full step by step fitting instructions with colour guide
Here are the numbers offered:
Qty 20 £150 inc shipping with DHL,Total of £7.50 each shipped ($12.08 can) or
Qty 1 £13.87 inc shipping ($22.34 can)
Seems to be a hard offer to beat.
I am looking for someone in Vancouver (assuming most interest by volume) to carry this through as I live on the island and would add to the shipping cost. If interested, someone PM please and I will get you in touch with Mark.
