Hey there - I am in need of a headlight combo switch for my 1992 exceed. CCA does not have any available at the moment. Does anyone have one that works and that is for sale?
Thanks in advance.
Headlight Combo Switch
- delicat
Re: Headlight Combo Switch
I know Mardy brings some new from japan, might be your best bet. You could also ask Golfcart, he's got a lot of 1st hand experience with the problem...and might have suggestions for you.
Might be worth to consider installing a remote headlight control...
Good luck!
David
Good luck!
David
Do you mean the switch assembly on the steering column?
Mine is on the way out so I was going to buy this one:
http://www.japanoid.com/store/index.php ... cts_id=243
but I should take it apart and fix it at least once before I replace it.
Richard Dagenais
Thanks guys. RichD - That is what I mean, although my wiper switch is working just fine. I have had the headlight switch replaced and repaired a couple of times, so am on to looking for a good used or even a new one, but they are pretty expensive new.
David - have you installed a remote headlight control (or anyone else)? Not really sure why the headlight switch keeps failing, but have read that it is pretty weak. I guess by installing a remote headlight switch that it takes the strain off the switch, which then becomes a turn signal only?
- Vehicle: -
quadzilla, this is a pretty common problem caused by too much draw from new headlights/lightbulbs. Make sure you wire in your headlights/DRL in the way like TardisDeli recommended: http://www.delica.ca/forum/headlight-re ... -7815.html
Yeah - I have looked at that post multiple times and to be honest I have left the wiring up the experts - I would likely screw it up. I was aware that the headlight switch was weak and like the idea of either a dedicated headlight toggle or the wiring setup that tardis posted. Either way, someone else will be doing it for me
. Need to get a hold of a decent used or new switch first.
