Engine parts for sale_L300
Posted: Fri Jun 04, 2010 2:23 pm
We are selling various parts for your 2.5L delica and pajero engine rebuilding ( 4D56 ).
All are new, unless stated otherwise.
1. camshaft $120
2. camshaft sprocket $30
3. front bearing cap $70
4. cylinder head $800
5. head gasket $120
6. intake valves (4) ; $80
7. exhaust valves (4) ; $100
8. intake rocker arm ; $30
9. exhaust rocker arm ; $30
10. injector nozzle tip gaskets $40
11. fuel return pipe gaskets.$30
12.clutch fan assembly ; $160
13. crankshaft(standard) ; $700
14. key-crankshaft ; $20
15. head bolt ; $ 15
16.crank pulley ; $ 180
17. balanceshaft sprocket ; $40
18. balance sprocket washer ; $30
19. crank shaft sprocket ; $ 40
20. main bearing set ; $190
21. head gasket set ( engine full set ) ; $300
22. crank shaft seal ( front and rear ) ; $50
23. connecting rod bearing set ; $60
24. transmission ( used ) ; $1600
25. cylinder block ; $900
26. radiator ; $250
27. alternator ; $290
28. starter ; $290
29. turbo ( new ) ; $1100
We do L300 engine ( Delica, Pajero ) overhaul at competitive price.
If need any other parts that are not in the list, ask us as we can get them in a week.
1. camshaft $120
5. head gasket $120
26. radiator ; $250
28. starter ; $290
