Would a compass from an L400 fit into the L300 Pod? That is not my project but curious as I may look to replace my Altimeter as well as my inclinometer. I rather like the temp guage so that would be staying.
cheers
Call me BCDelica-lessCMDelica is right again!BCDelica wrote:Having done this a couple times, but with the disclaimer added that I haven't in two years time, know it is a simple matter of carefully removing the front plastic molding below the pod first. It pops straight forward, and done carefully you will not break the two restraining clips. Removing that cover allows access to the two Phillips screws that allow the pod to be lifted, but of course its still connected to the inner wiring.
I broke both of the described plastic covers on our L300s, but found that a dab of silicone in each corner, and an elastic band around the base to hold the strip well drying lasted just fine.
