The first 5000km
Posted: Sun Apr 18, 2010 5:25 pm
				So, it's been 5000km already! Hard to believe we picked up Monty less than three months ago.  Anyway, I changed the oil this weekend, and these are some of the observations I made (for the driveway mechanic) while doing that, and while installing the rear hitch and the trailer wiring harness:
Overall, I'm happy with the SWB Pajero, and if we still had both of my step-daughters living with me, well, we might have gone for the LWB 4-door. I still miss the Delica, but I'm loving this new Pajero. Heck, even my dad is interested for when he has to return his leased truck next month.
 Anyway, I changed the oil this weekend, and these are some of the observations I made (for the driveway mechanic) while doing that, and while installing the rear hitch and the trailer wiring harness:- -the 31" tires are great because I can shimmy under the vehicle for short periods without putting the vehicle up on the ramps;
 -the underside of the Pajero is much beefier than the Delica (should be more solid when I do get off the road);
 -the mounts for the trailer bar are more accessible;
 -the oil filter is located in a much better place, and it's oriented vertically (instead of horizontally);
 -the oil pan plug is clear of the frame, so when the oil comes out it doesn't splatter all over the frame (and then into the catch pan);
 -the oil cooler holds a lot of extra oil which comes out all over hell's half acre when the oil filter is backed off (much messier);
 -and, the extra height and having to reach over the engine bay necessitates a stool or step ladder to reach the oil filler cap if ramps are used (might try it flat on the ground next time).
 Maybe next time I won't be such a slop.
 Understand? Of course it makes perfect sense when I describe it that way - right?
