As I look through older posts looking for part #'s there seems to be alot of differences.
example:front pads PGD530c or PGD349
front calipers slc8055u or 8033u or 0771059s or 0770545s
rear shoe 524pg or 510pg or gls6686
I don't want to cheap out on brakes so what all am I looking for to do front and back pads, shoes and calipers. I would like to upgrade to high end (raybesto?), and if so do I need all matching raybesto shoes, calipers, cylinders and pads, or how can I intermatch,depending on availability and necessity. Do I have to change the rotors aswell.
Getting everything from lordco would be handy. Thanks in advance for any help.
Matt
ps.I just got my 2.5'' side exit exhaust done at quiet muffler thanks to the advice on this forum. they did a good job and it cost $336 with a nice ss tip
brake part numbers
fozzie
- Vehicle: '90 delica exceed
- Golf Cart
- Vehicle: 1992 Exceed
Re: brake part numbers
Matt,
Are you doing the upgrade ?
Delica L300 = 88-89 Montero front brake pads/rotors/calipers
Dual piston upgrade on the L300 = 92-94 Montero front brake pads/rotors/calipers
Lordco has all in stock or in their wharehouse. Reybestos for pads n shoes. BeckArney for rotors/calipers.
Note : BeckArney brake pads for stock single piston ran me 26 bucks - same in Reybestos was about 90
Total Upgrade was 390 for the front with my discount
fozzie
hey thanks for the advice G.C.I don't think I will be doing the upgrade. I don't feel it's something I really need. Maybe if I knew it was gonna be a simple bolt on application I would but I'll just stick to what I know this time around. What's the best between ceramic and organic though. I'll probably go with what ever Mardys got. he knows what these things need. cheers matt
