Better L400 urban mileage in second ("Hold") gear?
Posted: Tue Dec 01, 2009 10:07 am
I do a large percentage of my driving on the level here in the concrete jungle in Vancouver, and I'm finding that the torquey-ness of the motor is far more than sufficient to shove the beast around at a good clip.
I have to be fairly gentle on the throttle to avoid a noticeable shift from 1-2; I think the transmission is working just fine, only that first is geared a bit low for my needs. My gutless old Corolla would upshift at the slightest provocation (unless you really had your foot deep in the throttle) and was smooth as silk. I also sense that my fuel economy would be better served by running in taller gearing.
So I've been running for a while with the transmission in "Hold" mode, and the 2-3 shift is much smoother. You move off at a slightly more sedate speed, but it is still more than enough to toodle around in traffic.
My plan was to run a tank full in regular mode and a tank full in "Hold" mode, and report if I find a noticeable difference in mileage, but...
I'm wondering if running this way over a longer-term would be bad for the engine/tranny in any way. It still spools up to around 2Krpm (where the torque peak is) fairly quickly, so I don't feel that I'm lugging the engine in any way, and I'd downshift to first on short and slow steep hills, but I thought I'd see if anyone out there with more diesel drivetrain experience than me has any thoughts on the matter.
Tony
Tony
