Can a secondary tank (wvo) be installed under the vehicle?
And if so how large could it be (Liters) and could a filler/vent be easily routed?
David
Quick questions for Pajero owners
- delicat
Re: Quick questions for Pajero owners
Hi David
On the SWB, there is zero room for extra's.
On the LWB, there is a small area on the left-hand side (passenger) of the vehicle in the middle section where a small tank could be fitted. It would need to be cut and sized to fit as it's not a straightforward box fit. I'm not sure of the size. I'm guestimating around 20-30 liters.
What I had planned originally was to use the main tank (95 liters) as the WVO source and the small area (above) for diesel.
You can probably route a filler or split the stock filler to route into small new diesel tank as well.
- delicat
Ok, thanks Jesse.
Seems like we may have a new Pajero in the family in the new year or maybe one of Mardy's Korean truck...
