got a hit and run on the van..
91 delica
need a rear bumper and inner, corners are ok.. please help!! need to get the van fixed..
thanks in advance!
91 delica need rear bumper
Moderators: delicanuck, mark
vintagefarms
- Vehicle: 91 delica
Adam
Re: 91 delica need rear bumper
Where are you located? I have a chrome bumper from a Super Exceed in Nanaimo.
The 'bumper' that comes stock on Delica's is in reality a plastic trim bumper ontop of a thin piece of bent metal not much thicker than a pop can. It protects nothing.
Last rearender I saw, it barely tapped the outside bumper. The inner bumper shell looked fine but the unibody was caved in slightly.
Make sure the unibody isn't touched. If it is, then it may be in the thousands to re-align and repair.
If it's a hit and run, get your insurance to cover it if the damage is extensive (you may not notice it but they may)
Adam
Oh yeah, I guess what I have is the rear nudge bar, is that right? I always mistakenly call it a bumper. It seems more bumperish than the plastic step. CCA has used bumpers list for $100: http://www.ccautos.ca/udp.pdf
