Rising temp on the Coquihalla
Mad Max
- Vehicle: 94 Delica
Ok so I have searched the site for ideas on over heating issues. I had already replaced the rad, water pump, etc. when I did the timing belt. The temp hasn't moved except when I was climbing the Coke. Finally gave in and turned on the heater fan with temp on high...in 40+ degree weather it wasn't fun...but it held the temp in check till we got to the top. My sense is this is a weak fan issue. Any hints out there on how to improve the fan effeciency on these units?
- delicat
Re: Rising temp on the Coquihalla
How high did it go? (past 3/4?) It's normal with your weather to go up even with all your new parts. It also depends how loaded you were. Do you have a re-cored copper 3 rows or the aluminum 4 rows radiator?
Also, is your fan working properly? Sometimes the clutch gives up... You could replace it with a electrical fan, it's been discussed here before and Sean did it on his.
Good luck!
Good luck!
After doing the rad pump etc...
Going up the coq just back off the throttle.
I averaged 80ish last time because my exhaust temps were through the roof.
Doing the coq three times in the Summer I just had to go slow.
3/4 temps and having to turn on the heater is unnecessary unless you're on the throttle too hard.
- sasquatch-hunter
- Vehicle: 2 Delica
Try some Royal Purple Ice.
Mephisto
- Vehicle: 90 5spDelica, 93 2.8 5speed SWB Paj
As jfarsang said, back off a bit to lower your EGTs. I just did the coke and my water temps barely went up and that's with the original rad, I just kept my EGTs around 1200*. It means you go a little slower, but, you won't be the vehicle at the side of the road with issues.
Watching EGT's is the key. If you want a real test for your system try the Little Fort Hill when it's 35 C. It's longer and steeper. I was in 2nd. gear @ 3000 rpm's to keep control of the temperature.
