Lake time!
Firesong
Lake time!
Post by Firesong »
The Delica pulled through the past week at the lake.
Literally. We used it to launch and pull out the boats
the entire time. I spose I should grease it up now.
That and dry the whole thing out. We had two
boats going in and out, a little 16 ft lund aluminum
and a large Starcraft hmm 20 ft (not sure) being put
in and out.
It was cool getting all the looks. My old VW could
never do this :)
Firesong
Re: Lake time!
Firesong wrote:...That and dry the whole thing out....Firesong
Did you have the boat ON TOP of the van?
Firesong
Re: Lake time!
Post by Firesong »
lol
no, you just drag in a lot of water getting in and out to hook up etc
some of my backing up the boat into the lake depended on me
and my 10 yr old daughter :)
So I did have to get my feet wet.
FS
TardisDeli
Re: Lake time!
Post by TardisDeli »
Ahhh, grasshopper, my secret is to remove the rear bench and put in the sleeping platform, or lie all the seats down with headrests removed. So now I can reverse with the rear door open up full and SEE my trailer hitch, and reverse to get close to hitch, apply parking brake, then crawl in back to stand on trailer hitch and not get feet wet (hint, bolt a flat plate about a foot square to trailer tongue just aft of hitch to stand on). No Wet Feet in My Deli! Cheers, Christine.
impalator
Vehicle: L300
Re: Lake time!
Post by impalator »
Right on...!
Had a great time last week in the Shuswap... Delica and Trailer worked out perfect (only launched boat 3 times though).
The third time my 25hp Johnson gave up on me (fortunately not far from the shore... so I rowed back to the launch - much to the amusement of onlookers....)
Does anybody recommend a good and affordable (i.e. inexpensive) outboard motor repair / maintenance place in the Vancouver area?
Thanks and cheers,
Chris
Firesong
Re: Lake time!
Post by Firesong »
Can't help with the repair shop but a quick comment.
I can't lay seats down and remove them to go to the lake.
4 kids and a wife make that impossible.
Instead I simply have to drive it close to the dock
jump up on the rear tire, swing around using the rack (carefully)
and tie it up.
It was a good time. I think I unloaded the two boats over 30 times.
We were in an area you need to take them out else things go missing
and / or the smaller boat gets waves coming over the back when beached.
By the end I could maneuver a trailer like no ones business. We even went
in at a strange angle since some moron decided to moore his boat in the launch
like a 'Mooron' ;)
J
another pic of the campsite with small boat and stuff
pic of campsite with the small boat. Wish I had a cover for the boat.
Lunch time at the vehicles
Delicaman
Vehicle: 1992 Super Exceed
Re: Lake time!
Post by Delicaman »
What kind of hitch do you have on your Delica?
impalator
Vehicle: L300
Re: Lake time!
Post by impalator »
Hi Delicaman,
I had my hitch mounted at a place called E&H Hitch in Burnaby (I believe they have a shop in Langley or Surrey as well).
Sorry - I forgot to post images on how it is mounted... will have to do this on the weekend (totally forgot to crawl under and take photos - as per my earlier Hitch / Bumperette-Post).
Outboard repair recommendations anyone?
Chris
Firesong
Re: Lake time!
Post by Firesong »
Not sure who you were referring to for a hitch.
Being that I started the thread I will post too ;)
http://www.delica.ca/forum/hitch-yes-an ... tml#p40929
Here's my hitch history :)
I trust it to pull anything.
Not sure if my brakes would stop 'anything and everything' :)
J
