Tranny cooler
Posted: Wed Jun 10, 2009 9:13 am
Would it be wise to install a tranny cooler?
I will be towing approx 1400lbs. 13' Boler.
Forum for Mitsubishi Delica owners and enthusiasts.
http://delica.ca/forum/
mararmeisto wrote:It already comes with one, and two oil coolers.
A Boler shouldn't be much of an issue as long as you monitor your rpms and drive accordingly.
I decided to have a look, not to be an ass, but to ensure that consistent info is getting presented. Bruce states it slightly differently.mararmeisto wrote:Transmission cooler on the driver's side under the step, air conditioner on the passenger side, oil cooler at the bottom of the radiator, and another behind the nose piece. With the radiator itself, that makes five cooling systems for this engine, making it quite robust.
Mystery Machine wrote: Just for reference, there are 5 different rads found on an L300 auto.
The main one just in front of the engine is for the engine cooling.
The silver one in front of that is the A/C condenser.
The long thin one mounted in the front grill is the oil cooler.
The one in front of the drivers side front wheel is the A/T cooler.
The one in front of the passenger side front wheel is the secondary A/C condenser.
HTH??
Regards,
Bruce.
