1991 Exceed/auto
My tail lights quit. So did the dash lights and side lights. I found out when I switched the engine off with the headlights still on. No buzzer, but then the motor didn't quit either. Even with the key out. Turn off the lights, and she quits. I've had the switch apart, cleaned up, and it seems ok. All known fuses are ok.
Where is that buzzer anyway, and what does it look like?
Another wierd wiring issue
- nootkase
- Vehicle: 1995 LWB L400 Silver
Meanman
Re: Another wierd wiring issue
sounds like your "multi switch" is cooked.....pretty common. Will your running lights come on with the fog light switch? If they do then almost gauranteed the "multi switch" is fubar. Get ahold of Glen at CC AUtos in Coombs. He seems to always have one in stock.
- TardisDeli
Buzzer is mounted on fire wall just to the left of the steering wheel shaft hiding behind some brake lines ,its a pain to reach also be aware there to modules side by side there and i can't remember which was which. Good luck Jay Tardis Deli
Christine
- nootkase
Hey, Meanman,
Whatsa "multiswitch"??
The thing on the steering column works fine. Had it all apart and clean.
Fog lights have always had a mind of their own. DRL's and Hi/lo's are fine. I would like to find a fuse for tail/panel lights, but so far, nada.
Bob
Bob
