An issue that seems to crop up frequently is calcified/petrified cooling systems. On the assumption that the cooling channels in the engine will be as clogged as the rad/hoses, just re-coring and swapping tubes won't necessarily cure overheating ills.
One thing that has crossed my mind (I've never tried it before) would be to follow up a re-rad/re-piping with a generous engine flushing with a de-calcification solution like CLR or the like.
I don't know if there are any of the engine internals that would dissolve along with the calcium
Call me BCDelica-less
