tires and metric conversion
pedro
- Vehicle: exceed 5 spd
I try the search for the best part of an 1/2 an hour but nothing came up! is someone have a tire chart for conversion into metric(e.i.: 31/10.50R15=X/Y R15). I got confusing info from 2 different shop and I figure that one of the 2 doesnt know what they are talking about( but I dont know witch one
) thanks for the help. pierre
pedro
Re: tires and metric conversion
nevermind, found it on redrock 4x4.com
30X9.50 R15 = 235/75R15
31X10.50 R15= 265/75R15
32X10.50 R15 = 265/80 R15
33X12.50 R15= 315/75 R15
N.B. : the metric mesurement are approximation
- delicat
Yup, approximative 'cause 235's aren't 30's but closer to 29's.
Check this link, you might find it useful:
http://www.1010tires.com/TireSizeCalculator.asp
Salut,
David
Salut,
David
pedro
So after trying it the other way( with the same site) I get different numbers
if you put 30X9.50 R15 in, it will give you 241/79 R15. than if you put 235/75 R15, it will give you 28.9X9.30R15. I'm a bit confuse , but how cares, I was just wandering if the 32" in metric would be a bit smaller in metric size and therefore fit , alas, no.
I guess I will try your suggestion David. Later
Meanman
you can do the math yourself a 235/75 r15 tire is 235mm wide the 75 represents 75% of tire width equals sidewall height.
therefore 235mm wide = 9.4 inches (25mm per inch)
sidewall height 235 x .75 = 176.25mm or 7 inches per sidewall
so 7 inches x 2 =14inches plus the 15 inch rim = 29 inches overall tire height
But...in Canada tires are sized "No wider than, no taller than" so any two different brands with same sizes are seldom the same size (very important for 4wd vehicles).
Hope this helps.
Hope this helps.
- deligate
- Vehicle: 95 super exceed l400
g'day mate give this site a go its a gr8 application
http://www.redrock4x4.com/tech/tire_calc.php
its a conversion application from metric to imperial
hope this helps
mick and the delig8ter
hope this helps
