my CVI day !!
Posted: Wed Mar 18, 2009 10:12 am
Well ,what can i say that has not been said before about these guys ? !!!! I don't know but i have to say something anyway !!!
WOW WOW WOW !!!
I thought i would just drive there hang out for an hour or two and then call the s/o to come pick me up.............. lets just say that did not happen. I was there all day.
I thought it was great to get to be there getting dirty (although edwin is good enough he does not even get dirty. I think it is because he moves too fast for the dirt to stick !! )
Here is the list:
-rotated tires
-lubricated chassis (11 points)
-tightened all suspension bolts (makes a huge difference !! )
-set valve clearance
-cleaned injectors
-replaced timing belts
-replaced tensioner pulley
-replaced fan belts
-replaced water pump
-replaced themostat
-replaced radiator
-replaced radiator hoses
-adjusted kickdown cable
-replaced oil seals
WOW what a big list !! My vehicle drives like new !! The thing is, he did all this work and also did a womans suspension and an oil change for another delica as well as answering the phone every ten mins. !!!! I have not seen a harder worker in my 15 years as a full time worker !!! The best part was that nothing was done half-assed . He took the time to clean everything and scrape the old seals off etc.....etc.....
Butch was a pleasure to deal with !! I would have no problems telling anyone to go there !! He even let me use his car to get myself some lunch !! I did not speed butch i promise !!
Now go out and break your delicas so you have a reason to go there !!!
cheers isaac
WOW WOW WOW !!!
Here is the list:
-rotated tires
-cleaned injectors
-replaced fan belts
-replaced themostat
-replaced radiator
-replaced oil seals
cheers isaac
