hello all!
well my trusty van is about to roll onto 90k and when it dose I'm planning on bringing it down to cvi for the full belt/pully/cvi delica tune jobby.
I was just wondering if anyone with experience in this department could enlighten me with a ball park number as to what this will cost. I know the old saying "if you have to ask you can't afford it" but it is more just me wanting to prepare myself for the suspectedly large number.
No matter what it costs I can't complain though, after almost 2 years of trouble free driving, the van deserves it!
Thanks, have a delitastic day
Ryan
Almost belt time
SquamptonRyan
- Vehicle: 1992 Toyota Hilux 2.8 Quad Cab
RaddCruisers
Re: Almost belt time
A quote can be tricky, as the list of parts that might have to be replaced will be different for every vehicle.
I would recommend:
Rad cap
Rad hoses - with fresh all-stainless hose clamps
Cooling system flush
Fresh Coolant (will require at least 6 litres)
Water pump
Thermostat & gasket
Fan/Alt Belts
PS Belt
A/C Belt
Idler pulley bearing as needed
Timing component kit:
-Timing belt
-Balance belt
-Cam, crank, balancer seals etc. (4 pieces)
Lube, Oil & Filter
Load test batteries
Test alternator output & diodes
Labour times will vary depending on what gets done.
Definitely go for the most complete job you can afford.
~John
I would recommend:
Rad cap
Water pump
Thermostat & gasket
Fan/Alt Belts
PS Belt
A/C Belt
-Timing belt
-Balance belt
Lube, Oil & Filter
Load test batteries
~John
E4 Auto Repair Ltd.
& Radd Cruisers 4WD
Duncan, BC
250 746 8977
& Radd Cruisers 4WD
Duncan, BC
250 746 8977
- loki
I agree except (unless it was already done) the rad will most likely need to be replaced or at least recored.RaddCruisers wrote:A quote can be tricky, as the list of parts that might have to be replaced will be different for every vehicle.
I would recommend:
Rad cap
Water pump
Thermostat & gasket
Fan/Alt Belts
PS Belt
A/C Belt
-Timing belt
-Balance belt
Lube, Oil & Filter
Load test batteries
~John
just my opinion.
Direct from the department CVI : (604)-247 0500.SquamptonRyan wrote:well my trusty van is about to roll onto 90k and when it dose I'm planning on bringing it down to cvi for the full belt/pully/cvi delica tune jobby.
RaddCruisers
Sorry, forgot to mention belt tensioners in my list.
~John
~John
E4 Auto Repair Ltd.
& Radd Cruisers 4WD
Duncan, BC
250 746 8977
& Radd Cruisers 4WD
Duncan, BC
250 746 8977
- MardyDelica
change the radiator if you can. all this delica radiator came from japan is plug 100%.
if need i have some coming end of this month.
we can do this timing belt service also. give me a call if you need help.
i have all the parts for your delica.
Cheers;
mardy
Cheers;
mardy
- Erebus
- Vehicle: 1992 Super Exceed
I wouldn't wait until it hits 90k. The normal maintenance spec is 90k OR 5 years. If your's is now 15 years old, it is long overdue. I would do it immediately.SquamptonRyan wrote:well my trusty van is about to roll onto 90k and when it dose I'm planning on bringing it down to cvi for the full belt/pully/cvi delica tune jobby.
"I could be just around the corner from heaven, or a mile from hell." -- Jackson Browne, "The road and the sky".-
petterz88
- Vehicle: honda 2.0 2000
I would recommend:
Rad cap
Water pump
Thermostat & gasket
Fan/Alt Belts
PS Belt
A/C Belt
-Timing belt
-Balance belt
Lube, Oil & Filter
Load test batteries
~John
well thanks for the help tips here, im actually looking for this ...
_________________
Everpure Filters
