				car seats
				Posted: Sat Jan 17, 2009 2:17 pm
				by Jamesandnicole
				We are wondering if there is an easy and safe way to attach a baby car seat to a captians chair?
James and Nicole
				Re: car seats
				Posted: Sat Jan 17, 2009 3:54 pm
				by delicat
				Yes!
If you have a post Aug. '91 with the 3 points seat belts all you need is to install an anchor to the base of your captain chair. One simple way is to use the existing hardware at the bottom of the chair, remove the nut, install the anchor and re-install the nut. (I've used the one that are facing down under the seat towards the back.)
I'll see if I can find pictures for you. But yes, easy and safe...
David
				Re: car seats
				Posted: Sat Jan 17, 2009 4:28 pm
				by jwfchase
				the seatbelt locking h-clip also works on the shoulder belts, but not on the lap belt-only that is mounted on the seat.
				Re: car seats
				Posted: Sat Jan 17, 2009 11:01 pm
				by Jamesandnicole
				Thankyou for the info. If some photos could be sent that would be great. Thankyou for the quick reply's. We are also new to the "Forum World" and hope we are replying correctlly.
James and Nicole
				Re: car seats
				Posted: Sat Jan 17, 2009 11:17 pm
				by jwfchase
				if you do have an older van w/just the lap belts, carseats will still work fine on both outer seats on the bench in the back, but not the cpt. chairs
				Re: car seats
				Posted: Sat Jan 17, 2009 11:26 pm
				If you are in the Lower Mainland area then I would advise you to go to a mini meet that is occurring in North Van on Sunday morning (tomorrow) at 10:00hrs at a coffee shop called "Beans On Lonsdale" (18th & Lonsdale). There you will get a lot of good advice with live demonstrations by none other than DeliCat, who has experience in this subject. And that's not all... There will be others there who also have experience regarding things that you have not as yet thought about... smiles.
				Re: car seats
				Posted: Sun Jan 18, 2009 1:52 pm
				by The Pinkfingers
				There are several threads about car seats (some with pics) - try the forum search feature (top right hand corner).  We've installed car seats.  The quick way to install the anchor takes about three minutes, but then you can't use the swivel feature of the chair (not that you would want to swivel a baby around, but...)  The less quick way that enables the swivel feature to still work take about 10 minutes.
				Re: car seats
				Posted: Mon Jan 19, 2009 9:42 am
				by Fishtank
				James and Nicole
Have a look here
http://www.delica.ca/forum/child-seat-t ... 45-15.html this may help with your anchor installs.
