Air/Heating/defog fan not working
Posted: Sat Nov 08, 2008 5:51 pm
by Gyaku
With the BC winter fast approaching I cranked up the Deli this morning only to find that I have no fan to defog my window. It was working yesterday!
I have checked the fuses under the drivers side and behind the glove box. I did discover one that was blown.... now my AC condenser fan is working but still no defog.
Is there another secret fuse? Or will I be spending the rest of the weekend pulling the dash off to get to the fan.
Any thoughts or suggestions would be greatly appreciated.
David
Re: Air/Heating/defog fan not working
Posted: Sun Nov 09, 2008 12:40 am
by storm80y
Have you tried with the headlights on? Mine appears to boost the fan when it's engaged and it's possible the switch that controls this feature could be faulty. Sorry, I don't have any better advice.
Posted: Sun Nov 09, 2008 9:42 am
by thelazybrownfox
fuses only blow when a wire, switch, or motor shorts to ground. Find the source of the short before replacing a part. You may end up replacing the part again.
Front Blower
Posted: Wed Nov 19, 2008 3:04 pm
by Gyaku
Does anyone have any idea where the front blower is located?
Do I have to remove the entire dash to get at it?
David
Posted: Wed Nov 19, 2008 4:37 pm
by Green1
I think you can access it behind the glove box, try that first.
Posted: Wed Nov 19, 2008 11:41 pm
by DelicaMark
Mine does this from time to time. My fix is to give the fan unit a bang with my fist and that seems to unstuck things. Not trying to be funny that is really what I do.
-Mark
Posted: Thu Nov 20, 2008 1:08 am
by Gyaku
I'll take another look in the morning and give it a kick:)
From what I have figured out... far left is the fresh air/recycle air intake, then behind the line fuses is the A/C, and behind the vent control is heating. Since I have the cool box I can't get a good look in the middle. I'm hoping I have missed something on the left side and the blower is between the intake and A\C. The entire system is packed in tight so I will have to start at the far left by taking out the intake.
If the fan is toast I might try to replace it with a stronger one..... not "Tim the Tool Man" strong, but a little more power wouldn't hurt.
Any thoughts?
David
Posted: Thu Nov 20, 2008 4:02 pm
by Gyaku
Found the fan......
Thanks Mark,
I gave it a kick and it started up again.... I guess the fan upgrade can wait until summer.
I really would like to get a labeled diagram of what is under the dash. My Deli service manual barely mentions anything about the A\C and heating system.
David
Posted: Thu Nov 20, 2008 6:52 pm
by DelicaMark
That's awesome! I especially like how this major issue of a couple of days ago can now wait until much much later to fix. That is
soooo Delica ownership!
-Mark
Posted: Thu Nov 20, 2008 7:17 pm
by Green1
That's awesome! I especially like how this major issue of a couple of days ago can now wait until much much later to fix. That is soooo Delica ownership!
so... if I kick my injection pump will it last until spring?
no?... oh... well it was worth a try...
Posted: Thu Nov 20, 2008 8:20 pm
by Gyaku
One point of humor......
My wife's father worked on big diesel engines most of his career..... his first tool for every problem was a small sledge hammer....
Personally I like to figure it out and fix........ I stand corrected again......
The inlaw had a big laugh over this one...
David
Posted: Fri Dec 05, 2008 6:31 pm
by The Pinkfingers
I'm going to try the kick method with mine, which isn't working either.
Posted: Fri Dec 05, 2008 11:01 pm
Gyaku wrote:I really would like to get a labeled diagram of what is under the dash. My Deli service manual barely mentions anything about the A\C and heating system.
Check this out:
http://www.delica.ca/forum/delica-techn ... s-292.html
Posted: Fri Dec 05, 2008 11:04 pm
by Green1
Check this out:
delica-technical-data-sheets-292.html
No climate control diagrams there...
seems that the climate control system is the only system in the vehicle that I haven't been able to find a manual or diagram for, I've been asking on here and on the UK forum for over a year now, and nobody has come up with anything yet...
Posted: Wed Jan 18, 2012 9:55 am
by yojimbo
Land Rover Special Tool #1 looks just like a lumphammer.
