				Changing Air Filter
				Posted: Wed Oct 29, 2008 9:28 am
				by skully
				I was wondering if anyone could help me out and point me in the direction of the air filter?
It needs to be replaced but not sure where to find it.  And any suggestions on a good
replacement brand?
				Re: Changing Air Filter
				Posted: Wed Oct 29, 2008 9:32 am
				by after oil
				try a search, or go to the wiki from the forum page.
the airfilter is behind and under the drivers seat..
				Posted: Wed Oct 29, 2008 10:23 am
				by delicat
				Behind the front driver wheel... It's a big can that has 2 clips (no tools required). Take off the cap and unscrew the bolt that holds your filter. One of the easiest maintenance on your Delica!
				Posted: Wed Oct 29, 2008 5:06 pm
				by Green1
				access it from under the vehicle, immediately behind the front driver's wheel, remove the clips and the cover will come off, then you undo the wing nut and the filter itself comes out.
				Posted: Wed Oct 29, 2008 6:06 pm
				by mararmeisto
				skully wrote:I was wondering if anyone could help me out and point me in the direction of the air filter?
replacement brand?
I like the WIX brand, a bit cheaper than K&N and more paper accordion-thingies inside (better filtering). WIX number 42222.
				Posted: Wed Oct 29, 2008 10:52 pm
				by Schwa
				I didn't change mine for a while, but I should have checked it a lot sooner...  The plastic turbine thingy was cracked and there were two washers (a new one comes with the filter) stuck to the wingnut, one of them still with the packing tape!
