BLOCK HEATERS
Posted: Wed Oct 15, 2008 10:00 am
by EnviroImports.com
Hello , we have the Delica/Pajero Block heaters now in stock, they are selling out fast, so if you would like them, please email or call, 12 Month warrantee included
$39.88
Re: BLOCK HEATERS
Posted: Thu Oct 16, 2008 4:24 pm
by ccautos
Lordco also now have lots in stock at only $37.73 !!! Last check they have over seventy in stock . Part number 310-0049 for the steel one or 310-0051 for the brass .
Re: BLOCK HEATERS
Posted: Thu Oct 16, 2008 7:13 pm
by delicat
Thanks Glenn,
Always nice to have this kind of help on this site, might suck a bit for other vendors but that's the name of the game.
Brass vs. Steel, pros and cons? And how much for your install?
Thx,
David
Re: BLOCK HEATERS
Posted: Thu Oct 16, 2008 7:33 pm
by ccautos
Brass ones don`t corrode as bad as the steel ones but they are getting hard to find as Temro disposed of the casting molds and no longer produce them . Steel ones are getting in more plentiful supply and are being kept in greater numbers by the `big guys` (Napa,Lordco) .
When we install them I quote two hours plus any coolant used . That equates to $150 labor and approx $19 coolant .
Re: BLOCK HEATERS
Posted: Thu Oct 16, 2008 7:59 pm
by delicat
Thanks again Glenn, very reasonnable!
If you have a brass one in stock please save 2 for me... will PM
Re: BLOCK HEATERS
Posted: Sat Nov 01, 2008 7:01 am
by Katabatic
what type of block heater we talking about? Frost Plug type or rad hose?
Re: BLOCK HEATERS
Posted: Sat Nov 01, 2008 9:06 am
by robinimpey
Frost plug type. Goes in the block behind the starter.
Re: BLOCK HEATERS
Posted: Sat Nov 01, 2008 11:34 am
by hasid33
Just called Lordco and they said they have no brass ones left in their system at all, I'm getting steel for a steal, thanx for the part #'s
Re: BLOCK HEATERS
Posted: Sat Nov 01, 2008 3:57 pm
by mararmeisto
robinimpey wrote:Frost plug type. Goes in the block behind the starter.
Is there a threaded hole where it gets screwed into or is it in-line with the coolant hose? Is this a driveway job? Any pictures?
Re: BLOCK HEATERS
Posted: Sat Nov 01, 2008 4:44 pm
by patty
so i had the block heater installed and everything.stopped all problems i was having with starting.fired up right away everytime with little to no smoke.thne one day everything went back to shit. mind you this is also not even in cold weather yet, like +10c.
now i figure its something to do with my outlet that im plugging into( blown fuse or something)any one have nay other ideas?r some of the block heaters faulty noel?
Re: BLOCK HEATERS
Posted: Sun Nov 09, 2008 7:43 pm
If your having any problems, I would first reach down and check to see if the cord came off the block heater, when you had it installed the installer might not have put the cord on very tight. There really isent anything to go wrong with a block heater, its a simple element.
Noel
Re: BLOCK HEATERS
Posted: Sun Nov 09, 2008 8:02 pm
by delicat
Don't want to steel anyone's thunder but I found those heater plugs at Lordco using Glen's part number and if you have an account they are about $25 each...
Re: BLOCK HEATERS
Posted: Tue Nov 11, 2008 11:39 am
by Leafster
FYI, just ordered one of these from Lordco, they charged me $60!!!!
Re: BLOCK HEATERS
Posted: Tue Nov 11, 2008 11:56 am
by Golf Cart
Leafster wrote:FYI, just ordered one of these from Lordco, they charged me $60!!!!
I just called Maple Ridge store, in stock , $30 with a good guy price
Re: BLOCK HEATERS
Posted: Tue Nov 11, 2008 10:57 pm
by trialsmaster2
I'm in the same boat as Golf Cart. I picked one up last night and it was $30 before tax after my discount at our local Lordco.
