Page 1 of 2
Lowered, and raised!
Posted: Sun Oct 05, 2008 10:56 am
by delicat
I recently bought a '92 Excel for my wife as mine didn't fit into her work underground (6'6"). It took her less than 1 hour to get used with the LHD and now she loves it! :-D But she didn't love so much that she kept on scratching the roof everytime she'd drive into her underground. (Nice yellow marks on the roof now, compliment of the warning bars).
So I had the choice between getting smaller tires or lowering it. Didn't feel like increasing the revs by putting smaller tires so I took her van to Canada Springs and went the opposite direction as Falco... I got them to re-index my leaves springs. The van was effectively lowered at the rear by 2". The front was already low enough to clear and actually sits level now. I might lower the torsion bars a bit but I'm happy for now.
The side step by the sliding door was already lowered by the previous owner in Japan... but all of those will be replaced by the chrome ones that I'm removing/removed from my truck.
Lowered, close up.jpg (58.71 KiB) Viewed 13415 times
All I need now is to find some nice larger rims with lower profile tires to fill the wheel arch nicely but that's for later... AND just to keep the record straight, this one is a city Delica that likely won't see any mud but will still come handy when we have snow for 5 days/yr to drive up where we live (way up on a hill).
I got her van directly from Japan and was lucky that not much really was needed as far as initial maintenance goes. Her van also came with an amazing exhaust system, full 2 1/2" stainless with Mandrel bends! And pimped out under carriage side lights! lol
Hers and his....jpg (65.43 KiB) Viewed 13441 times
As far as mine goes, I went the other way and jacked it up. I'm not done with the project yet, still have to install my rear shackles but it's getting there! So this is what it looks like when you re-index and crank your torsion bars, you can see how the front sits higher than the rear (I kinda like the look actually). I also put some new mud 31" that I love! They aren't very loud on hwy but offer tons of traction offroad. (I also had to put new wider rims as my originals were only 6 1/2") I was out with Falco last weekend in Chilliwack and although he's got all-terrain he'd be slipping on many occasions while I thought I was on dry pavement!
Here's my little one getting trained on WVO use, he already loves it!
My helpers.jpg (73.78 KiB) Viewed 13408 times
This picture is before I re-indexed my torsion bars... Those rims are actually Split-rims that come apart, nice! And they are really thick, nice again!
Front tires.jpg (91.71 KiB) Viewed 13424 times
Tires, side view.jpg (37.04 KiB) Viewed 13397 times
I also got some new/used foglights that come with a high/low control. These things are BRIGHT! They came handy last weekend as well...
New fog lights.jpg (67.08 KiB) Viewed 13397 times
So still have loads of mods to do but doing a little at the time, which is why I love those trucks so much... always something else to do!
David
Re: Lowered, and raised!
Posted: Sun Oct 05, 2008 11:03 am
by konadog
Nice work David! LOVE those gnarly split rims! Very cool. Must be fun having two delis, esp. having a town bus and country bus! :M :-D
Posted: Sun Oct 05, 2008 11:17 am
by Jester
That's a very good idea.
I have a similar problem with my van.
It does fit in my underground without scraping, except when it's hot outside- I guess everything expands and the gate hangs a bit lower, and perhaps the roof sticks out a fraction more..
Did lowering you did change the load caring capacity?
Martin
Posted: Sun Oct 05, 2008 11:35 am
by delicat
Yes, lowering it means I can't carry as much as before but since this is a "cool soccer mom minivan" I didn't care too much. It still find for most application except a full load of gravel... The cost was under $400.
The van rides fine, only when hitting a very sharp bump I hear it at the back but I might still have to do some minor adjustment. Could also be the exhaust hitting the springs... I could have lowered it 1" or 1 1/2" with less issues but I just asked them for as low as possible while maintaining as much of the initial ride as possible. It does drive more like a sport car though, not a bad thing for a city vehicle. That's why I may lower the torsion bar so the front gets softer a bit (it's always been very stiff at the front compared to my other one).
Posted: Mon Oct 06, 2008 8:00 am
Nice contrast between the two 8-)
Posted: Mon Oct 06, 2008 11:02 am
by patty
If you dont mind me askin, how much did your tire and wheel combo set you back on the white one?
Posted: Mon Oct 06, 2008 2:08 pm
by delicat
The tires were picked up in the States but since they are made here in Canada I didn't have to pay duties. They were $150 each.
http://www.tirerack.com/tires/tires.jsp ... es&place=3
The rims I have no idea yet, I traded them in return of help & parts.
Posted: Thu Oct 30, 2008 10:01 pm
by ExplosiveAbe
PM sent.
Posted: Mon Nov 03, 2008 10:03 pm
by capslayer
Friggin awsome looking. It looks like your tires may rub. Have you had any problems?
Capslayer
Posted: Wed Jul 01, 2009 10:24 pm
by pototoy
i'm loving all the mods you've done to the deli so far......
Posted: Thu Jul 02, 2009 2:08 am
by delicat
Thanks Pototoy!
But that's only a fraction of the mods on my van. One day I should really build a post on all of them... :-D
Posted: Thu Jul 02, 2009 6:31 am
by pototoy
tooo bad i can't get 1 of this delis here california.... :-( i should move to canada
Posted: Thu Jul 02, 2009 6:37 am
by delicat
Ya, I feel for you... These would be perfect out there!
Posted: Mon Jul 06, 2009 8:29 am
by pototoy
^^ can i see pics of the wifey's deli..... specifically the section where the rear suspension (leafsprings) got lowered... i need to lower my van a bit cause my moms having a hard time going up n down this thing. as for the front... i'm just gonna tweak the torsion bolts a bit
by any chance 15x8 would work on our vans; as in; would it clear the rear sliding door??? ..... looking to get this puppies (rims only), shipping them to asia (where my rig is at)
Posted: Mon Jul 06, 2009 11:19 am
by delicat
Can't post pics as I'm out of country and no access to either vans, sorry.
And I'd doubt the 15x8 will fit the front without some lift or cleaning the wheel arch. They'll probably rub but again, that depends of you tire size and wheel offset... As for the rear it depends of the offset but easier fit.
