250 gallon tote fits in delica!
Posted: Sat Aug 30, 2008 4:33 pm
by after oil
Image Hosting
the rear bench is out.the front bench is facing back and the door closes no prob!
this can be your WVO tank!
Re: 250 gallon tote fits in delica!
Posted: Sat Aug 30, 2008 4:59 pm
by Adam
Nice job you can drive forever with that as your tank
I didn't even attempt to fit my totes in the back, as I have a friend with a cube truck
. Do you know if anymore of those are available? A biodiesel producing friend of mine is looking to increase his capacity.
Posted: Sat Aug 30, 2008 5:07 pm
by after oil
Adam wrote:Nice job you can drive forever with that as your tank
more are available, i PM'ed you
Posted: Sat Aug 30, 2008 8:57 pm
by loki
I've been after 2 of these totes for months, I get someone saying that they get them but never hear back that they have any :(
Posted: Sat Aug 30, 2008 9:27 pm
by mararmeisto
Of course, if you FILL it with WVO, that would be more than 300kg, right over the rear wheels
Posted: Sat Aug 30, 2008 11:31 pm
by Adam
mararmeisto wrote:Of course, if you FILL it with WVO, that would be more than 300kg, right over the rear wheels
I would think it would be closer to 1000kg. Would make for good traction thought
Posted: Sun Aug 31, 2008 12:18 am
by clintonian
I am curious, how much are they to obtain, and where do you get them from?
Clint
Posted: Sun Aug 31, 2008 2:09 am
by mararmeisto
Adam wrote:mararmeisto wrote:Of course, if you FILL it with WVO, that would be more than 300kg, right over the rear wheels
UNITS! I always did get picked up for that in math class.
You're right, at 250 gallons, that would put it at 1136 litres, which would be mean approximately 870kg! Traction, for sure.
Posted: Sun Aug 31, 2008 9:42 am
by Erebus
mararmeisto wrote:You're right, at 250 gallons, that would put it at 1136 litres, which would be mean approximately 870kg! Traction, for sure.
870? If you filled it with water, it would be 1136 kg. Is WVO that much lighter than water?
Posted: Sun Aug 31, 2008 10:17 am
by after oil
those totes are a dime a dozen up here in PR! well, $140 from the farm store and $100 from a neighbour who is also a feed supplier.
i didnt know they were so hard to get, maybe i should try to arrange something for my fellow delica.ca members
Posted: Sun Aug 31, 2008 10:21 am
by BCDelica
Someone should figure the distance you'd get with that much weight and fuel onboard? Where to store your gear though.
Posted: Sun Aug 31, 2008 10:24 am
by mararmeisto
Erebus wrote:mararmeisto wrote:You're right, at 250 gallons, that would put it at 1136 litres, which would be mean approximately 870kg! Traction, for sure.
I found a reference to olive oil which estimated 7.7 lbs per gallon... so I went from there.
Same thing in the submarine: we actually get heavier the more fuel we burn (water-displacement fuel system). This makes it tricky for compensating, because the longer we go without fueling, the less water we have to use to correct the trim (because we've already got a bunch more in than when we started)! Neat, eh?
Posted: Sun Jun 14, 2009 3:38 pm
by Jonny5ive
I need two of these and I live on the island... Victoria.
I'm starting a small WVO co-op and I need all the bits and bobs... so if anyone on the south-side island area has a spare tote, pump, heater &tc... let me know.
Any tips or advice would be helpful.
I already have my source for oil.
Posted: Wed Jun 17, 2009 7:16 am
by Chewy
Jonny5ive, in Nanaimo, there is an esso commercial area, right down near the ferries at departure bay. They have a few of these I saw for sale the last time I was down there.
Posted: Wed Jun 17, 2009 11:49 am
by Luna-Sea
Hey,
I will check that out today on the way to work.
I will feel like a bit of a dumbass if they are so close to my house,
I have been all over hell's half acre looking for them.
Right on!
