Included:
New Timing Belt & Balancer Belt
New Water pump & Thermostat
New Belt tensioner.
New Front Wheel Bearing Inner and Outer
New Bushings
New Front Rotors
New Front Brake Pads Semi Metallic
Oil Change with 15w40
Transmission Fluid change with Dextron 3
Transfer case fluid changed with Chevron Delo
Front and Rear Differential fluid Changed with Chevron Delo
Radiator acid clean and recore if necessary
All suspension parts re greased.
New Filters (Oil, Fuel and Air)
4 Brand New Yoko Geolander AT/S 6 Ply
New Headlights DEPO with proper DRL hook up and new bulbs.
Complete Detailing (Engine, interior, exterior).
