Page 1 of 2
				Is my turbo working???
				Posted: Thu May 29, 2008 7:41 am
				by piyeguyo
				Didn't want to hijack another post, so I'm creating a new one.
Green1 was saying his turbo is not working... and I'm wondering how does one test this???
If I want to know if the turbo in my van is working, how do I do it?
Thx,
Fabio
				Re: Is my turbo working???
				Posted: Thu May 29, 2008 8:43 am
				by marsgal42
				Your first test is to listen. The 4D56T engine sounds like any other turbocharged diesel. You'll hear a faint whistle on acceleration, but only from outside the van.
Beyond that you need to hook up a boost gauge.
...laura
				Posted: Thu May 29, 2008 10:28 am
				by Schwa
				A boost gauge can be purchased at princess auto for $12-$17 depending on what sale is on.
				Posted: Thu May 29, 2008 2:08 pm
				by Green1
				I can't speak for your vehicle, but here is how I know mine isn't working:
- biggest clue is the "psst...psst...pssst" sound anytime I push hard on the accelerator, this indicates that my "boost" is going straight out the waste-gate instead of doing anything useful
- next clue, much less acceleration than other Delicas I've compared to, and harder to maintain speeds up steep hills (I have however learned to operate the vehicle in such a way as to stay out of the "turbo" and as such have better fuel economy than most delicas)
- it "just feels like" I don't have a turbo working... hard to describe unless you've driven diesels with and without...
				Posted: Fri May 30, 2008 6:43 pm
				by JMK
				How do you hook up the boost guages and what sort of information do the return? Are they able to rate the realtive efficiency of the Turbo, or does it just tell you if it is working or not?
				Posted: Fri May 30, 2008 8:17 pm
				by Schwa
				The gauge will show you 'how hard' the turbo is working by tapping into the air line that goes to the injection pump from the turbo with a tee...  It is useful if you are trying to mind your fuel economy, high boost (+ RPM) = burning lots of fuel.  Generally they don't tell you much directly, but can be interpreted to extrapolate information, as well as tuning the turbo's maximum boost.
				Posted: Fri May 30, 2008 9:42 pm
				by JMK
				Thanks Eric,
So in Green1's case, would it still appear as though the Turbo is working, or would it return a nil reading? Any downsides to hooking them up and then leaving them in place?
				Posted: Fri May 30, 2008 10:16 pm
				JMK wrote:Thanks Eric,
No. It's a good thing. Just like a pyro gauge.
One for the boost and one for the temps.
Jesse
				Posted: Fri May 30, 2008 11:02 pm
				by JMK
				SOrry for all the questions but now that you have me convinced, one last (I think) question: if you buy a gauge do you need one specific for Diesel or do they all work?
				Posted: Fri May 30, 2008 11:11 pm
				by delicat
				They all work and should read boost up to about 20lbs average (you'll only need readings up to 15lbs). Pretty straight forward install. And Green1 vehicle shouldn't read any boost if his turbo isn't working (or very very minimal?).
David
				Posted: Fri May 30, 2008 11:18 pm
				by JMK
				Thanks Guys,
I was just looking at one on eBay, a Timex, wondering if it would be worth it. Some posts say the cheap $20.00 gauges from eBay are not worth buying, but I suppose they'd be as good as anything from Princess Auto for the same price.
BTW, really want to impress your friends?
THis guy posted plans on how to build one from a Palm Pilot!
				Posted: Sat May 31, 2008 10:03 am
				by JMK
				I was told by our mechanic if I was going to use the above, to be sure to also put in an exhaust gas temp, as that is the most important one for pressurized engines.
				Posted: Sat May 31, 2008 3:32 pm
				by delicat
				Exhaust gas temperature gauge = pyro gauge... same thing, or that's the way I understand it anyway. (Until EricN proves me wrong again!)
David
				Posted: Sat May 31, 2008 8:03 pm
				by EricN
				Tried to think of something buddy but you are right. pyrometer = EGT.
				Posted: Sun Jun 01, 2008 10:05 pm
Jesse
delicat wrote:Exhaust gas temperature gauge = pyro gauge... same thing, or that's the way I understand it anyway. (Until EricN proves me wrong again!)
David
