intermittant violent shaking
Posted: Wed Apr 09, 2008 4:30 pm
				Hi,
so it started yesterday, a strange mild shaking that occured occasionally while driving. not directly related to any speed range.
today it got really bad but again only occasionally. heavy vibration, shaking from what i assume is coming from the driver's side wheel. when i break the steering wheel shutters pretty hard. but also bad when just driving straight.
a syptom that i think must be related is that it appears the front drivers side caliper is sticking a bit (there is more heat coming off the rotor than their should be).
then all is fine and van runs smooth.
up until now the breaks have been fine, no significant pulsating upon stopping, but perhaps the mild sticking of the caliper combined with a slightly imbalanced rotor could be causing this? but it sure feels like the drivshaft is suddenly bent and flailing! and then not...
where do i get a new caliper? i saw one post about lordco but i got the predicable blank stare when i asked.
thanks for any input you might have!
Martin
Martin
