DELICA AND PAJERO PARTS LIST
Posted: Thu Feb 07, 2008 3:06 am
by mdrive
THEROMSTAT GENUINE MITSUBISHI $25
THERMOSTAT AFTERMARKET $15
AIR FITLER DELICA $17
AIR FILTER PAJERO $20
PAJERO WATERPUMP $130
DELICA WATERPUMP $120
ENGINE REAR MOUNTING AT GENUINE MITSUBISHI $75
OIL SEAL 66 GENUINE MITSUBISHI $13
OIL SEAL 65 GENUINE MITSUBISHI $13
OIL SEAL 36 GENUINE MITSUBISHI $13
OIL SEAL 63 GENUINE MITSUBISHI $13
TIMING BELT GENUINE MITSUBISHI $55
BALANCER BELT GENUINE MITSUBISHI $50
TIMING BELT UK $40
BALANCER BELT UK $35
TIMING TENSIONER GMB $40
BALANCER TENSIONER GMB $40
ALTERNATOR BELT GENUINE MITSUBISHI $35
AIR CON BELT GENUINE MITSUBISHI $25
POWER STEERING BELT GENUINE MITSUBISHI $25
ALTERNATOR BELT AF $15
AIR CON BELT AF $15
POWER STEERING BELT AF $10
FUEL FILTER AF $16
FRONT SUSPENSION LOWER ARM MITSU L300 AT OEM $105
OIL FILTER AF $15
GLOW PLUG RELAY DELICA GENUINE MITSUBISHI $ : A MD155274 $105
GLOW PLUG RELAY DELICA : B MD121037 GENUINE MITSUBISHI $105
GLOW PLUG REPLAY PAJERO: A MD169409 GENUINE MITSUBISHI $105
GLOW PLUG REPLAY PAJERO:B MD121037GENUINE MITSUBISHI $105
GLOW PLUG MITSU DELICA/PAJERO GENUINE MITSUBISHI $40
GLOW PLUG MITSU DELICA/PAJERO AF $20
TEMP SENDING UNIT GENUINE MITSUBISHI $55
ALTERNATOR DELICA 110 AMP AF NEW $250
ALTERNATOR PAJERO 110 AMP AF NEW $250
MASTER CYLINDER OEM $65
MASTER CYLINDER KIT AF $25
MASTER CYLINDER KIT OEM $35
CLUTCH SLAVE CYLINDER OEM $65
CLUTCH SLAVE CYLINDER AF $45
CLUTCH SLAVE KIT AF $25
CLUTCH SLAVE KIT OEM $35
REAR BRAKE CYL ASSEMBLY OEM $50
TIE ROD END OUTER OEM $45
TIE ROD END OUTER AF $35
LOWER CONTROL ARM BUSHING OEM $25
UPPER RADIATOR HOSE DELICA OEM $45
LOWER RADIATOR HOSE DELICA OEM $45
UPPER RADIATOR HOSE PAJERO OEM $45
LOWER RADIATOR HOSE PAJERO OEM $45
COMPLETE MUFFLER OEM $250.00
SHOCK ABSORBER L300 GENUINE $75.00
MITSUBISHI L300 REAR GLASS OEM $350
MITSUBISHI L300 WINDSHIELD OEM $300
REAR BAKE HOSE OEM MR129784 OEM $35
FRONT BRAKE HOSE A 771 OEM $35
FRONT BRAKE HOSE B 744 OEM $35
FRONT BRAKE PADS AF $40
FRONT ROTORS AF $55
CLUTCH DISC AF $70
REAR BRAKE SHOE DELICA AF $60
REAR BRAKE SHOE DELICA OEM $80
L300 DELICA HEADLAMP DEPO $250.00
HITCH WITH BALL $380
PAJERO HEADLAMP DEPO $250.00
MB749 FRONT AXEL HUB BEARING OEM $45
MB447 REAR AXEL SHAFT BEARING OEM $45
MD130 M/T COVER FRT BEARING RETAINER GASKET GENUINE MITSUBISHI $7
MD703796 M/T UNDER COVER GASKET GENUINE MITSUBISHI $7
MD705865 M/T COVER REAR GASKET GENUINE MITSUBISHI $7
MD739566 TRANSFER COVER ADAPTER GASKET GENUINE MITSUBISHI $7
MD736299 TRANSFER CHAIN COVER GASKET GENUINE MITSUBISHI $12
MD704138 TRANSFER FRONT OUTPUT SHAFT GASKET GENUINE MITSUBISHI $7
MD704137 TRANSFER REAR COVER GASKET GENUINE MITSUBISHI $5
MD187507 OIL PAN STRAINER GENUINE MITSUBISHI $40
VALVER COVER GASKET GENUINE MITSUBISHI $22
**PRICE SUBJECT TO CHANGE DUE TO AVAILABILITY FROM SUPPLIER. **
Re: DELICA AND PAJERO PARTS LIST
Posted: Thu Feb 21, 2008 3:22 am
by mdrive
WE ARE NOW CARRYING OIL PAN HEATER. 150 WATT, SIMPLE INSTALLATION WITH HIGH HEAT SILICONE. PRICE $45.00
Posted: Tue Feb 26, 2008 8:15 pm
by bae146
Do you have a price on Pajero windshield? Gen 2. Do you install as well? I will be out in bc this summer and I will need a windshield by then. Mine is getting cracked up pretty good.
Posted: Sat Mar 01, 2008 3:24 am
by mdrive
Please contact us after April, we will have Pajero Windshield, installation can be done as well. Thanks.
Posted: Thu Mar 13, 2008 9:57 am
by Katabatic
Do you still have this...MITSUBISHI L300 REAR GLASS OEM $375...in stock? Im also looking for a replacemnt "DELICA" green lit up reflector on the rear door
Posted: Fri Mar 14, 2008 12:56 am
by mdrive
We have two in stock now, the rear reflector coming end of next month (used). Thanks
