Hey guys,
I've got a 1993 starwagon delica... just snapped a fan belt and still hear squeaking when i drive. So, i'm going to order new fan belts. Any suggestions where to order from or if you know what the VIN number is for this type of fan belt?
I am currently in California.
Thanks in advance. Appreciate the insight/ info
Danielle
Fan Belt... where to order?
gonewiththewind
- Vehicle: Delica Mitsubishi
DeliTan2
- Vehicle: L400 Series 1 LWB
You posted in L400 Technical but I suspect you have an L300. Is the engine under the seats or under the hood?
Doesn't matter. You can get fan belts from almost any auto parts dealer, anywhere on the planet.
The number you need is written on the belts (if still legible)
If illegible, you will likely need an L300 owner to respond.
Is this a diesel engine? If so, you have twin fan belts, and you need to replace them both at the same time with a matched pair of belts from the same batch. Genuine Mitsubishi belts are best, part number MD313660 (there are two belts in the packet).
There's a set on Ebay right now: https://www.ebay.com/p/MD313660-Mitsubi ... 2176608770
gonewiththewind
Thank you Growlerbearnz.... super helpful! Bought them on ebay :) Been to a few shops here in town but was not able to match them, so i appreciate the tip !
demiro
- Vehicle: Delica
Can't go wrong with OEM part. I got mine on ebay also.
