				fuse box (wiring diagram)
				Posted: Sun Jan 27, 2008 10:57 am
				by jesse
				I helped a buddy out the other day jumping his civic, like an idiot I didnt check to see if he had placed his jumpers properly, anyway my right running light is now out, could it be a fuse ? or should monkey around the bush bar and take out the headlight,, the reason I ask is its minus 10 and I dont wanna work on it outside,
white 92 exceed penticton
				Re: fuse box (wiring diagram)
				Posted: Sun Jan 27, 2008 11:58 am
				by delicat
				Here's some info:
FUSE BOX:
Starting top left, with the ratings for additional guidance:
10A Room, 10A Hazard, 15A Horn, 10A Stop, 15A Head(upper), 15A Head
(upper), 15A Head(lower), 15A Defog, 20A Rear heater, 20A Door lock.
(I'm assuming that Head (upper) is High beam, although not sure why
there's two, unless one for each side. Either that or one is the fog
lights)
Lower:
15A Wiper, 15A Lighter, 15A Rear Lighter, 20A Sunroof, 15A Turn, 20A
Heater, (Then 4 spare slots)
You may very well have shorted your DRL module... something to keep in mind.
Good luck.
				Posted: Sun Jan 27, 2008 1:20 pm
				by Green1
				hard to say for sure, but I would say in order of likelyhood:
- DRL module
- fuse
- bulb
- other wiring?
however from a troubleshooting stand point, start with the easy stuff:
- fuse
- bulb
- DRL module
- other wiring?
				Posted: Mon Jan 28, 2008 9:43 pm
				by john n
				The drl module will have diodes in them, heavy loads backfeeding from the civic after it started will have fried them.
Check all fuses in the fuse box and look very closely at your battery to make sure there are no fusible links that have burned.  They will look like regular wires, just put a test light on them to ensure that they have current.
Do your lights work okay with the normal switch?
If so change out the drl module.
If not - remove the drl and try the main headlight switch again, in case the drl module is interfering with the normal headlight switch.
