TieMyShoe's Grinded Cam
takeuchi
Vehicle: 1992 Starwagon Super Exceed
Post by takeuchi » Sat Apr 14, 2018 9:32 am
I ended up getting ahold of one of TieMyShoes Grinded cams, so I thought I would post my thoughts on it after driving with it a while.
It feels like my van doesn't bog down as much going up hills or trying to accelerate at highway speeds. Usually I feel a large dropoff in power once it goes past 3000 rpm or so but with the new cam it isn't as harsh. I don't feel like I'm much faster but maybe because it feels like I'm just not allowing down as much.
I also feel like the EGTs went down a touch as well.
Hopefully Cam can chime in on how much it costs.
Sent from my ONEPLUS A5010 using Tapatalk
TieMyShoe
Vehicle: L300
Post by TieMyShoe » Mon Apr 30, 2018 8:22 pm
Glad your happy with the new cam. The grind is designed to move the powerband of the 4D56 a moee usable RPM range. The stock cam has a bunch of grunt out of the hole but rapidly drops off. The new grind keeps you in the power band while criusing or under general acceleration.
I will be doing a second run when i am able to source out more cores. Prices can be expected in the 300-350usd depending on the size of the run.
canvanner
Vehicle: 1992 Delica Exceed P24W
Post by canvanner » Wed Jan 02, 2019 5:26 pm
Any thoughts on doing a cam grind for the 4G64 gas?! I've been thinking about it but not really sure where to go...
