Ok I have now begun to embark on my electrical install in my van, my first quandary is where to pick up for my relay ignition. I was thinking that the alternator would be perfect and quite easy to work from. But I have seen others use a splice in headlights and other ignition activated sources. Has any body got experience with this. I'm on a 4d56t any help would be much appreciated.
Sent from my SM-G930F using Tapatalk
Pick up for my relay.
gledhillpete
- Vehicle: l300
What are you looking for? A wire that's only powered when the ignition is turned on, near the engine? There's a green/white stripe wire down by the air filter, in the big connector that goes to the rear aircon. It would be good for triggering a relay (but not really for powering anything directly).
Under the dashboard, well, there's plenty on the back of the fuse box, just check out the wiring diagram for a suitable candidate.
Overlanderjay
- Vehicle: Ford E350 Econodeli powerveg
I would tap in to the ignition harness the easiest place to get at it is at the bottom of the dash panel beside the steering column cheers Jay
"Electrickery Technition"
gledhillpete
- Vehicle: l300
Cheers guys, I think the ignition harness will be my point of attack, but yea it's just a trigger for the relay so no heavy draw through it.
