				I don't think this is a good thing!
				Posted: Sat Jun 10, 2017 6:19 pm
				by Confusedone
- 1-IMG_20170610_165905391.jpg (26.66 KiB) Viewed 3888 times
				Posted: Sat Jun 10, 2017 6:20 pm
				by 204explorer
				Broken timing belt?
				Posted: Sat Jun 10, 2017 10:11 pm
				by Growlerbearnz
				You're right, that's quite a bad thing.
The only silver lining is that the rockers are designed to break when the piston hits a valve, rather than bending the valve. You'll still have to remove the head and check all the valves for straightness, the head for cracks, and the cam and its bearings for alignment, but you might get away with just replacing those rockers and the rocker shaft. Obviously check the remaining rockers for cracks too.
Watch for stripped bolt holes on the cam caps and rocker shaft bolts. They can be heli-coiled to repair them.
				Posted: Sun Jun 11, 2017 9:16 am
				by Confusedone
				THank you Growlerbearnz.
Good to know i may not have to replace the whole head!
