				4m40 engine rattle
				Posted: Wed May 03, 2017 2:22 pm
				by Avittery
				After doing some minor work to my engine I've noticed a loud engine rattle while driving ONLY between 1500-2000 rpm. Has been doing it for about 2000 km, but no other symptoms.
Doesn't do it in neutral, so its difficult to tell where its coming from in the engine but sounds like the driver's side.
I've looked online and some people have said perhaps the timing chain is loose or guides are worn, or it could also be the harmonic balancer...
Anyone else had this problem with their L400?
				4m40 engine rattle
				Posted: Sun May 07, 2017 3:23 pm
				by TRUTHautomotive
				What engine work did you do?  Did this only begin to occur following the repairs?
Sent from my Nexus 6P using Tapatalk
				4m40 engine rattle
				Posted: Sun May 07, 2017 10:59 pm
				by Growlerbearnz
				TRUTHautomotive wrote:What engine work did you do?  Did this only begin to occur following the repairs?
...and are all your screwdrivers/wrenches accounted for?
Rattling at one specific frequency makes me think of something loose that's shaking around. An engine cover, heat shield, or stray tool. It would be unusual for the balancer or timing chain to suddenly start rattling loud enough to hear, they usually start off so quietly you think you're being paranoid.
				4m40 engine rattle
				Posted: Sun May 21, 2017 8:27 pm
				by willskigilbert
				Same problem here .... Strange ratteling like somthing is loose but I cannot find where... Only seems to do it at lower speed when accelerating or decelarating. No clue but really anoying
				4m40 engine rattle
				Posted: Thu May 25, 2017 9:19 pm
				by Firesong
				Avittery wrote:After doing some minor work to my engine I've noticed a loud engine rattle while driving ONLY between 1500-2000 rpm. Has been doing it for about 2000 km, but no other symptoms.
Check your main drive shaft. Might need balancing or the UJoints done.
J
				4m40 engine rattle
				Posted: Mon Jun 12, 2017 9:56 am
				by willskigilbert
				For me it was the u joint.  They have been replaced and she now runs smooth. They are the same as the u joint on the montero.
