A big woops...
Posted: Fri Mar 24, 2017 9:18 pm
				So I had a little drip coming out of the sending unit on the rear tank....eventually the little drip turned into a bigger drip.
I happen to have another tank that still had the sending unit in place, so I figured I would just swap gaskets.
I started by the removing the sending unit from the spare tank. I sprayed the bolts with liquid wrench, lightly tapped then, sprayed some more...tapped some more; the nuts came right off - easy peasy. Removed everything, checked the gasket, cleaned the gasket which in good enough shape that I could use it.
I figured I would try the same procedure on the leaking unit; spray, tap, spray, tap and remove.
But no such luck, as soon as I wrenched on the first nut...snap. The bolt broke off.
The pic cleanly shows my handy work.
https://goo.gl/photos/rvfJjzrLeAF57xcy6
(sorry for the link, I could not figure out how to resize the pic to make it fit in the forum)
I tried Seal All to stop the now bigger leak...but no such luck.
Im not sure, but I think the other tank (tank body itself) I have is in worse shape then what I have on the vehicle...and I think it would be a LOT of work to check it for leaks.
Realistically though, I am sure my only option is to swap tanks, but I am wondering if anyone has a magic solution or some kind of snake oil goop I can put the sending unit to seal it up?
LMcD
LMcD
