4d56T block heater install
gustycrosswinds
Vehicle: delica l 300
Post by gustycrosswinds »
i've got a block heater that i'd like to install on my l300 p25w.
wondering if anyone has experience with this.
curious which frost plug to use, or if it matters.
thanks
lrp374
Vehicle: 91 Super Exceed
Post by lrp374 »
One option:
viewtopic.php?f=6&t=12188&hilit=install+block+heater
a search will show others install behind the starter!!
lrp374
Post by lrp374 »
I finally found the one most use>
viewtopic.php?f=6&t=4260&p=32919&hilit= ... lug#p32919
Good luck!!
gustycrosswinds
that is helpful!
i'm not sure why my previous searches didn't produce these posts.
thank you
tomaboyd
Vehicle: 1991 Delica Exceed
Post by tomaboyd »
Or you could install a Wolverine. These are not expensive, easy to install and make a world of difference.
http://www.wolverineheater.com/
Furi
Vehicle: 1990 L300
Post by Furi »
tomaboyd wrote:Or you could install a Wolverine. These are not expensive, easy to install and make a world of difference.
How has been your experience with them? Under what conditions have you used it?
feetforbrains
Vehicle: 1991 Delica L300 Chamonix
Post by feetforbrains »
Anyone ever use a magnetic or glue on oil sump heater? What was your experience with these sorts of warmers?
Sent from my Pixel 2 using Tapatalk
ChuckBlack
Vehicle: L300 Jasper
Post by ChuckBlack »
Use a Pan Heater thats the brand... works amazing
L300 Jasper, :-D
L300 Chamonix, :-)
Pajero Mini, :-(
Pajero GDI :o
Pajero DiD 8-)
philmeup1
Vehicle: 1992 Delica
Post by philmeup1 »
I have a magnetic sump heater on my L300. It only seems to work if you plug it in right after you've parked it up from driving it the night before. If you put it on a timer to have it going a few hours before you're planning on starting your van the next morning, its just not enough to be effective. My understanding is that the frost plug is the best way to go. It's going down to -14 tonight here in Ontario. My van usually has no issues starting unless in gets down past -20 +. Hopefully there's no surprises tomorrow morning, or I'm just gonna have to be late for work:)
Ralph in Winnipeg
Vehicle: 94 Strada
Post by Ralph in Winnipeg »
I'm a big fan of the peel and stick Polar Pad from canadian tire. Check my Strada posts for more details. Ralph in Winnipeg
