Passenger Electric Window stopped working
Posted: Thu May 19, 2016 5:09 pm
by thelazygreenfox
My passenger side electric window stopped working :-( . There's no push button control from either the driver or pass side or power at the wire connector on the passenger side door.
The wiring diagram isn't much help cuz I can't find the connector that supplies power to the circuit boards in the doors.
The drivers side has power and works great. That eliminates the fuse unless the PS is fused separately.
Any ideas?? I will search the Auz and GB sites for answers as well.
I'd jumper out the window motor but I'm nor sure if that feeds back to the circuit board. :? There's also an end switch that hasn't been checked out yet. It's an awkward thing to work on. :-(
thanks :M
MD
Posted: Fri Dec 28, 2018 3:32 pm
by volnoir
I am having the same issue on my deli. Anyone have any ideas to troubleshoot?
Posted: Fri Dec 28, 2018 7:26 pm
by thelazygreenfox
#%^*@ delica
Update from 2016
Still have the same delica and have had additional delica electrical gremlins since. It seems that if you get out in damp enough weather some component will temporarily stop working. All my switches, wiring and fuses have continuity. The motors, when powered will operate and the end switches operate as they should.
Everything works but no power gets through till the weather dries up in the spring. While you have the doors apart, grease all the runners and pivot points.
The solution, "keep the windows up till the weather changes." Don't worry, be happy!!
MD :-D :-D
Posted: Fri Jan 04, 2019 11:12 am
by jamengual
I have a similar issue, in a cold day the windows do half way up not all the way.
In my Saab 900 I had the same issue and it is the motor regulator that protects it of overheating and melting and one way to solve it was to regrease the gears or bypass the regulator, it is just basically a tired motor.
I'm going to take mine apart and see how it goes.
