				power locks don't work
				Posted: Mon Nov 16, 2015 4:20 pm
				by jos_mclean
				hi every have a 95 l400 exceed with a power lock button, unfortunatly i have no power lock functions. anyone ever dealt with this issue? where do i start? already checked fuses. do not have a fob.
				Re: power locks don't work
				Posted: Tue Nov 17, 2015 8:14 am
				by Firesong
				Check the connection at the door hinge. Those wires can wear.
				Posted: Tue Nov 17, 2015 12:25 pm
				by Big-Bird
				The wires in the door jam area good palce to start.
The master switch (driver's door) may have failed. Or a relay under the dash has failed.
Go check the Deilca Technical Section for the electrcial manual.
Have you tried locking the door with a key? This also unlocks and locks all the doors.
If that still doesn't work then your issue could be at the main controller which is inside the right rear quarter panel (below the back rear window inside the panel).
Why Mitsu put it there is anyones' guess!
