				Bottle jack
				Posted: Tue Feb 17, 2015 2:44 pm
				by insideout
				I'm planning on putting a lift (2") and bigger tires (31") this spring. What height of bottle jack would I need once this is done? I only have the stock jack and I want to upgrade sometime soon. I saw at Canadian tire they have an assortment, but what is the min-max height I should get?
TIA
				Re: Bottle jack
				Posted: Tue Feb 17, 2015 2:52 pm
				by Triumph73
				Mine is lifted by 1.5".  I kept the stock jack because it fits nicely tucked in the corner.  I carry 2 cut off pieces of 2x10 I liberated from a scrap pile at Home Depot.  The help raise the height and also give you a stable surface to jack from if it's wet.  I also use them sometimes to level the Delica for sleeping.
				Re: Bottle jack
				Posted: Tue Feb 17, 2015 9:00 pm
				by insideout
				Oooo i will stop by home depot tomorrow and ask for scraps
thanks!
				Re: Bottle jack
				Posted: Wed Feb 18, 2015 12:55 pm
				by Big-Bird
				the top pin on my stock hydraulic jack threads out(up/down) to take up height differences found in the road.
you may not even need the wood block if you get an adjustable jack.
				Re: Bottle jack
				Posted: Wed Feb 18, 2015 8:17 pm
				by insideout
				Big-Bird wrote:the top pin on my stock hydraulic jack threads out(up/down) to take up height differences found in the road.
If i can avoid buying another jack i may  prefer that :)
