				all lights flicker slighlty at all times
				Posted: Tue Nov 18, 2014 10:32 pm
				by super7
				Just replaced my alternator and voltage is were it should bex but the voltage will change one tenth (.1) of a volt every half second. My engine speed is also rolling. I will change my fuel filter and check my wiring. Anything else it may be?
Regards,
Eric
				Re: all lights flicker slighlty at all times
				Posted: Wed Nov 19, 2014 2:30 am
				by Big-Bird
				loose connection either at the alternator or the battery.  A dirty/corroded battery clamp or cable. Loose ground cable at the engine or body from the battery.
Another item is the alternator could be faulty on the amperage output. A quick charging test at Partsource is free and worth the trip.
