WTB EGR blanking plate
Posted: Wed Nov 12, 2014 8:15 pm
Who is selling them? prefer in BC.
Forum for Mitsubishi Delica owners and enthusiasts.
http://delica.ca/forum/
Fixed that for you.... article is about gas engines not diesels...Yokohama wrote:Why you should KEEP the EGR ON A GAS MOTOR:
http://www.tuneruniversity.com/blog/201 ... you-money/
Yes, thank you! That would only apply if the OP has a gas motor.thedjjack wrote:Fixed that for you.... article is about gas engines not diesels...Yokohama wrote:Why you should KEEP the EGR ON A GAS MOTOR:
As an addition to Konadog's observation ~ put a machine screw into the end of the vacuum hose when you take it off.konadog wrote:If you don't want the EGR you don't need to put in a blank - simply disconnect the vacuum hose that hose that engages it.
