Major Failure: Please help with Diagnosis
Feds
Post by Feds »
I was heading off to camp yesterday, long trip down the 401 highway. About 2 hrs in I noticed my oil pressure dropping. 20 minutes later, the engine made a big knocking noise and started to run away (as in, I lifted my foot off the pedal, and it kept driving down the highway at 100 kph.
Pulled over to diagnose and I found: lots of diesel in the oil, and lots of diesel/oil coming out of the crank case vent hose and into the intake.
Can this be anything other than a failed fuel pump seal?
macro
Vehicle: L400 "The Invader"
Re: Major Failure: Please help with Diagnosis
Post by macro »
I can't help with the diagnoses, but I'll be working in Hannon all week so if you need anything from Right Drive I'm sure I could pick it up for you.
Mr. Flibble
Post by Mr. Flibble »
If you have diesel in the oil I would go with pump seal.
Unless you lost oil and compression on a cylinder and had diesel leak down that way, but you would have probably noticed the loss of power.
Pump seal is most likely IMO.
Feds
Post by Feds »
Thanks Marco. I'm going to make some calls on Tuesday and see if u can get a rebuilt pump shipped from rising sun or cvi.
