Buzzing during starting ( glowplug ecu issue? )
Posted: Tue Jan 14, 2014 10:45 am
				Hello,
I've had my van for almost 2 years now.
I bought a van that had been intitally serviced at CCA and it's been great.
I've done normal maintenance, it doesn't get driven a lot.
However for the past few days it seems like the glowplugs have not been working. They were replaced last year in march due 2 of the 4 old ones not working. The van has always started like a dream, cranked over after the relay click, even with 2 working glowplugs, there was only bucking afterwards.
So now the van cranks over just fine, it just doesn't start ( nicely! .. it will start just cranking the thing for a bit ). I have a strange new buzzing noise now under the dash with the key in the on position during glowplug warmup. I can still hear the glowplug relay click ~5 seconds after the key is on .. but it's not doing it's job.
the connection to the busbar is tight, as well as the glowplug-busbar connection.
i haven't been able to pinpoint the buzz noise, as after a few times it stops ( and the relay click stops as well.)
could this buzz be from the glowplug ECU? has anyone else had this problem?
Thanks in advance.
Thanks in advance.
 Once after I put an unwired Fog light switch and the other time with restarting my Van after having unpluged the ECU. For sure under the dash, close to the steering wheel, not to say on its left side. Any idea ?
