Hello all again.
Can someone please tell me the correct way to bleed the injectors on the 2.8 Paj, I believe I still have some air in the system.
I did a fuel filter change and when I started pumping the primer on the fuel filter housing to bleed the air out It started leaking and pushing more air back in. On my first attempt, the truck started for about 30 seconds then died and wouldn't start again. I pulled it all apart again, filled the filter up before hand, and tried to prime it again. It was still leaking but I managed to get some air out. The truck starts but it takes a lot longer than it did before the change, and I have to pump the pedal to get it going. Once its running it has not stalled once. Its just the starting that is the issue. My guess is that there is still some air in the system that is making it difficult to start. I thought maybe driving her hard would maybe bleed some out, but it has been like this for a week or so.
So now I would like to know how to bleed through the injectors if someone can help me out.
Bleeding injectors properly
- str8gooods
- Vehicle: Mitsubishi Pajero 2.8l SWB
yojimbo
Re: Bleeding injectors properly
Crack the injector unions slightly, crank until diesel comes out, and do them up. thats the normal routine on any diesel engine.
1994 L300 Jasper
1986 Scimitar 1.8Ti
1986 Scimitar 1.8Ti
- str8gooods
This being my first diesel, I have a few more questions. 1. Is it done one injector at a time, in which case is there a better one to start with. 2. Do I do something to prevent the truck from starting. 3. What exactly do you mean by union. Is that the upper bolt or the lower. Sorry if these are dumb questions, this stuff is quite new to me.
- str8gooods
Problem solved, Thanks for the help.
- str8gooods
So my starting problem came back again. I bled the injectors a few times, but after a day or so, the issue would come back. I then noticed that the fuel filter water sensor was dripping fuel from the nipple. For a quick fix until I can source a new one, I threaded a screw into the nipple. And problem has actually gone away. It's been 2 weeks and no more starting issues.
