Help w/improve fuel: currently@ 16.6 liters per 100 km/17mpg
Posted: Tue Jun 25, 2013 11:30 pm
Hi Folks,
Still a complete newbie here.
And as ever, stoked at the reads I get 'till late in the evening.
I'm writing tonight (and this morning to correct my mpg - kms conversions) because I've looked over the club for improving my 1993 StarWagon (Turbo Automatic ) diesel mileage because I'm only at best (highway driving), getting about 16.6 Liters per 100 km or 17 miles per gallon (U.S.).
Also, I didn't see a thread, "How to improve your MPG" but that doesn't mean it doesn't exist, it probably points to my less than stellar search skills.
Driver behaviour (me):
In any event, I don't think I'm that heavy footed, yet I admit, I do get it up to 120 K for a bit now and then, generally I find myself cruising at around 105-110 (65-75 mph). And I run the A/C often. Also, I try to keep my RPM in the 3000 range (+/- 100).
Car stuff (New Deli)
My EGR is now blanked / extricated (thanks to a cool kit from the Australia: http://www.ebay.com/itm/EGR-BLANKING-RE ... 97&vxp=mtr),
I have a 3.5 inch exhaust outlet (is that the right word, outlet? /
no it's not the right word, looked it up, it's an exhaust tip!.
Just changed oil, fuel filter, air filter, tran. fluid, radiator fluid. Prior to the EGR block, I was getting on my bad days, 19 L per 100 kms or 15 mpg.
Also, I also added a little fuel injector cleaner and some diesel additives (different one each time) to fill ups recently, and will do so again shortly.
Possible Remedies:
Maybe from Falco: injection timing and injection cleaner?
or valve clearances.
I dunno.
I also came across this at another site:
"I suggest anyone with a Delica can improve their MPG significantly by doing the following......
Regular servicing with fuel and oil filter changes. Injector cleaner every so often in the fuel tank. Fit an easy breathing Air filter like the Unifilter lifelong foam one from Millis Performance Cars (cheaper than an original and much better). Tyre pressures at maximum recommended. " from club delica:
http://www.mitsubishidelica.com/forum/v ... de090e63e4
So what now? I would love to get much, much higher numbers (wouldn't we all!)....
Thoughts?
1. Valve clearance check
2. Injection timing
3. Injection cleaning
4. EGR meter to slow me down (sorry Konna dog)
5. Tire pressure (increase)
6. Larger tires (ok, not till I run these ones down), but slower starts to speed
7. ?????
Peace
New Deli
Possible Remedies:
I dunno.
Thoughts?
2. Injection timing
7. ?????
Peace
New Deli
