Delica L300 new cylinder head and cooling mod
Posted: Sun Jan 27, 2013 9:33 am
				Delica L300 new cylinder head and cooling mod.
It seems that there is a lot of L300s with failing cracked/ warped cylinder heads, mine just happens to be one of them at 190,000 kms .
After a lot of searching I found one here for under $700.00 CND shipped UPS complete with a gasket set and new head bolts .
http://www.ebay.co.uk/itm/Mitsubishi-pa ... AQ:GB:1123
While waiting for the head to arrive I started prepping for the swap, with new injection pump seals, crank/cam seals timing belts etc. etc.
All the while reaserching as to why these heads fail in the first place it seems that the cooling system and not the aluminum or poorly designed cylinder head is the problem.
The 20 year old + viscous radiator fan coupling is a major culprit they are designed to spin fee at cool temperatures and lockup when the hot radiator temperature hits the thermostatic plate in front of it causing it to expand and engage a tiny valve which allows the silicon oil to flow and lock up the fan clutch. This is a genius design, working only when it has to and freeing up probably around 10 HP when it is not. The easiest way to test if it is working properly or at all is to run your engine until hot, shut it down and watch that the fan comes to a quick stop, if it continues to spin it has lost its ability to cool the radiator. Here are a couple of good reads about it.
http://www.4x4wire.com/forums/showflat. ... er=1223543
http://www.mitsubishi-forums.com/t41959 ... ce-fan.htm
The radiator itself is another major problem more than likely not properly serviced for 15 years as these vehicle are treated as disposable items in Japan . It is blocked by the AC radiator in front of it and an electric fan in front of that, and some more hot transmission fluid inside of it , is this the same guy who designed with the alternator tentioner ?
To allow for better cooling and to protect my new investment I decided to scrap the AC but keep the electric fan and frame for additional cooling ( easy drill out the 4 pop rivets and remove the fan bolts and the core slides right out) . I am planning to wire it to a temp. switch with a manual override for climbing hills and low speed 4X4 . Any comments on this mod would be much appreciated and welcome especially the temp. switch wiring.
During this repair it has occurred to me that the AC condenser would make a great donor for the transmission radiator, much bigger, built-in fan and would free up the engine rad for even better engine cooling.
My concerns regarding this mod are :
Proper decontamination, material compatibility, flow rate/ pressure restriction, etc.
This could be the L300 mod/ cylinder head saver, cheers, looking forward to any posts only relating to this mod, thanks.
