4WD clarity
Posted: Wed Jan 09, 2013 9:13 pm
Well if you live in calgary then you are covered in snow! so this brings me to a couple questions:
1) Driving in 2wd i have no lights on my 4wd indicator ( no green lights on my little wheels in the sweet picture) is this right?
2) The AWD system in delicas should operate in 2wd? as in a slip and grip system or i have to actively be engaged in 4 high?
3) When in 4 high i get the front to tires to light up on my sweet little delica picture on the dash correct?
4) Whne in 4HLc the center diff illuminated red and flashes.... how long does it take to lock the transfer case or will it continue to flash when the locked center diff is engaged?
Thanks and sorry for all the questions I rember a post somewhat descirbing the procedure but could not find it in the technical section
Thanks again
Thanks again
