Page 1 of 2
				L400 Brake Parts
				Posted: Wed Jun 20, 2012 10:41 pm
				by CloudMountain
				Are there any North American Brake Parts that can be used on the L400?
Also anyone know a Delica Mechanic in Nelson, BC?
				Re: L400 Brake Parts
				Posted: Thu Jun 21, 2012 12:42 am
				Jordan is in Nelson, he might be someone to talk to.
				Posted: Thu Jun 21, 2012 9:00 am
				by Feds
				CloudMountain wrote:Are there any North American Brake Parts that can be used on the L400?
Everything but the front rotors are equivalent to the 3.5l v6 montero.  Front rotors are L400 only.
				L400 Brake Parts
				Posted: Thu Jun 21, 2012 11:49 am
				by lettereleven
				Check around in here (the forum) - I was interested in the past and found lots of good info.
				Posted: Thu Jun 21, 2012 11:55 am
				by CREGAN
				Posted: Thu Jun 21, 2012 4:05 pm
				by CloudMountain
				Thanks for the info.
I found a guy out in Castlegar that works on Delica's (Kootenay Euro Shop) going to have him have a look Friday.
				Posted: Tue Jul 03, 2012 3:40 pm
				by prairiefire
				The Montero (95 or 94) has two different calipers on the front brakes based on the model/engine.
LS Model=3.0L and SR Model=3.5L
I've read to use either model to cross reference in various threads. The front and rear pads, rear calipers and rotors are the same on these models. In my search I've found they have different calipers. Can anyone confirm which is the "proper" model to cross-reference too.
post edited
				Posted: Tue Jul 03, 2012 7:48 pm
				by LeeHammy
				http://www.rockauto.com/catalog/raframecatalog.php
Click the European Union Flag check box and look up Mistubishi your year then Delica. Have fun.
				Posted: Tue Jul 03, 2012 8:16 pm
				by CREGAN
				Lee, I have tried searching around the RockAuto site and I can't seem to find a listing for the 2.8L Diesel engine on any of the Delica or Space gear listings.  Am I missing something?
				Posted: Tue Jul 03, 2012 8:20 pm
				by LeeHammy
				No possibly not. It doesn only seem to list the 2.5L but for brake parts does it matter? Check the measurements. They may be the same. Or try 2.8L Pajero. Just leading you to the site realy, if you have had a gander then I don't know what to say.
				Posted: Tue Jul 03, 2012 8:52 pm
				by CREGAN
				Ah yeah I guess for brake parts it wouldn't matter.  I have been trying to find NGK's on that site for a while though.  Prices seem pretty good, but Fishtank ordered some plugs from there a while ago and had to pay duty on them.  Don't forget.
Craig
				Posted: Tue Jul 03, 2012 10:37 pm
				by RichD
				prairiefire wrote:The Montero (95 or 94) has two different calipers on the front brakes based on the model/engine.
I've read to use either model to cross reference in various threads. The front and rear pads, rear calipers and rotors are the same on these models. In my search I've found they have different rotors. Can anyone confirm which is the "proper" model to cross-reference too.
For matching the front calipers and pads its Montero Sport V6 3L any year will do, even 2000-2003. They used this running gear for years and years.
While L400 front rotors are the same diameter the hub is different (bigger). You need to source the rotors through an importer. I know for sure these three keep them in stock and the price is decent; pick one: CC Autos, Rising Sun, Maximum Overdrive. Also John at RMI almost certainly has them. I would recommend asking for a price for all the parts from the importers as they might make it worth single-sourcing the works.
As for rear I have not confirmed a fit but I'm told Montero Sport V6 3L fits. Note some L400s have drums not discs in back.
Sourcing:
The calipers are cheapest at NAPA. The pads are about the same at both Lordco and NAPA. Note that there is some variety of quality of brake pads, as well as different compounds. I've tried both ceramics and semi-metallic; overall I prefer ceramic. If you cross the border often go to NAPA US and save about 30% but it won't be in stock; you'll have to pre-order. Mail order is available as well, similar delays. Notably: the front calipers and pads are the same as the L300 dual piston upgrade. Also I believe these are a match for Pajero. BTW I'm talking rebuilt semi-loaded here; I do not know of anywhere you can buy "new" other than perhaps an importer; it will cost much more and really there is no point.
Also note that every supplier (including NAPA USA vs Canada) have different part numbers. I've tried several "brands" of rebuilt calipers and they are all identical, so price matters. I have had one bad unit in about 5 pairs and it was from the more expensive supplier. They replaced it with free delivery.
I can post all the suppliers part numbers and best pricing I've gotten if you like.
Jesse is the master of info.
Still check your facts from multiple sources. Jesse is a close personal friend and I know for a fact that he admits to several mistakes on the forum that have been quoted all over the place and he hasn't the time or inclination to chase down and correct. Stupid things usually, not the big strokes. I can't count the number of times that I've googled something, got this forum in the first page of results, found a whole bunch of posts saying its
this and so I buy it but its not
this its
that and I have to go back and get the right thing. By the time I have wasted that time I am not thinking about correcting the forum. In fact usually I'm an idiot and don't write it down for next time.
				Posted: Wed Jul 04, 2012 6:33 am
				by prairiefire
				RichD wrote:For matching the front calipers and pads its Montero Sport V6 3L any year will do, even 2000-2003. They used this running gear for years and years.
There we have it folks. Search Montero 3.0L for front brakes. Thanks Rich for clarifying this. Any ideas whose front rotors are best locally? You can PM me to avoid ruffling some feathers if you like.
				Posted: Wed Jul 04, 2012 6:56 am
				by prairiefire
				RichD wrote:I can post all the suppliers part numbers and best pricing I've gotten if you like.
Yes please.
				Posted: Wed Jul 04, 2012 8:33 am
				by RichD
				prairiefire wrote:RichD wrote:For matching the front calipers and pads its Montero Sport V6 3L any year will do, even 2000-2003. They used this running gear for years and years.
Montero
Sport V6 3L. The sport part made a difference in lookups at a couple of places.
