How can i find out if my turbo is working properly.
Posted: Wed May 30, 2012 10:01 pm
by pr222
i have a 92 L300 exceed Turbo diesel 5 spd.
My turbo maxes out at 10 psi. It Idles at 0, there is no vac pressure.
How much vac pressure should there when idling?
How much boost should i get from the turbo?
Re: How can i find out if my turbo is working properly.
Posted: Wed May 30, 2012 10:08 pm
by sub-arctic
as far as i know the manifold will produce no vacuum pressure, thats why the back of the alternator has a vac pump built into it to run your brakes etc. there wont be any boost at idle because the turbo wont spool until higher rpm. not too sure on the boost psi though. anyone else have the numbers?
hope this helps
Posted: Thu May 31, 2012 6:54 am
by legionnair
10-11 is very standard, some people set hem higher Max is 15 but done at your own risk.
Sounds like yours is working great
Dustin
Posted: Thu May 31, 2012 11:12 am
by mararmeisto
"How can i find out if my turbo is working properly"
If you can achieve/maintain over 50 km/h on the highway...
Posted: Thu May 31, 2012 1:08 pm
by jwfchase
mararmeisto wrote:"How can i find out if my turbo is working properly"
Which highway?.... ;-)
Posted: Thu May 31, 2012 1:12 pm
When things go better on the Coque.... How's that for product placement?
